发表于 2021-1-28 13:53:29
37950
安装torch torchvison到AGX xavier  NX
帖子不让发链接,请下载附件确保链接正确
Below are pre-built PyTorch pip wheel installers for Python on Jetson Nano, Jetson TX1/TX2, and Jetson Xavier NX/AGX with JetPack 4.2 and newer.
    You can now download the l4t-pytorch and l4t-ml containers from NGC for JetPack 4.4
Download one of the PyTorch binaries from below for your version of JetPack, and see the installation instructions to run on your Jetson. These pip wheels are built for ARM aarch64 architecture, so run these commands on your Jetson (not on a host PC).
PyTorch pip wheels
PyTorch v1.7.0
PyTorch v1.6.0
PyTorch v1.5.0
PyTorch v1.4.0
PyTorch v1.3.0
PyTorch v1.2.0
PyTorch v1.1.0
PyTorch v1.0.0
Instructions
Installation
Below are example commands for installing these PyTorch wheels on Jetson. Substitute the URL and filenames from the desired PyTorch download from above.
> Python 3.6
wget  .. tyarwt5nvo6imenfy26 -O torch-1.7.0-cp36-cp36m-linux_aarch64.whl
sudo apt-get install python3-pip libopenblas-base libopenmpi-dev
pip3 install Cython
pip3 install numpy torch-1.7.0-cp36-cp36m-linux_aarch64.whl
> Python 2.7
wget  ... h6qcuaqco1qcsif.whl -O torch-1.4.0-cp27-cp27mu-linux_aarch64.whl
sudo apt-get install libopenblas-base libopenmpi-dev
pip install future torch-1.4.0-cp27-cp27mu-linux_aarch64.whl
(PyTorch v1.4.0 for L4T R32.4.2 is the last version to support Python 2.7)
> torchvision
$ sudo apt-get install libjpeg-dev zlib1g-dev libpython3-dev libavcodec-dev libavformat-dev libswscale-dev
$ git clone --branch <version> XXhttpsX://github.com/pytorch/vision torchvision   # see below for version of torchvision to download
Example:
$ git clone --branch 0.8.1 XXXhttpsXXX://github.com/pytorch/vision torchvision   # see below for version of torchvision to download
$ cd torchvision
$ export BUILD_VERSION=0.x.0  # where 0.x.0 is the torchvision version
Example:
$ export BUILD_VERSION=v0.8.1  # where 0.x.0 is the torchvision version
$ sudo python setup.py install     # use python3 if installing for Python 3.6
$ cd ../  # attempting to load torchvision from build dir will result in import error
$ pip install 'pillow<7' # always needed for Python 2.7, not needed torchvision v0.5.0+ with Python 3.6
Select the version of torchvision to download depending on the version of PyTorch that you have installed:
    PyTorch v1.0 - torchvision v0.2.2
    PyTorch v1.1 - torchvision v0.3.0
    PyTorch v1.2 - torchvision v0.4.0
    PyTorch v1.3 - torchvision v0.4.2
    PyTorch v1.4 - torchvision v0.5.0
    PyTorch v1.5 - torchvision v0.6.0
    PyTorch v1.6 - torchvision v0.7.0
    PyTorch v1.7 - torchvision v0.8.1
Verification
To verify that PyTorch has been installed correctly on your system, launch an interactive Python interpreter from terminal (python command for Python 2.7 or python3 for Python 3.6) and run the following commands:
>>> import torch
>>> print(torch.__version__)
>>> print('CUDA available: ' + str(torch.cuda.is_available()))
>>> print('cuDNN version: ' + str(torch.backends.cudnn.version()))
>>> a = torch.cuda.FloatTensor(2).zero_()
>>> print('Tensor a = ' + str(a))
>>> b = torch.randn(2).cuda()
>>> print('Tensor b = ' + str(b))
>>> c = a + b
>>> print('Tensor c = ' + str(c))
>>> import torchvision
>>> print(torchvision.__version__)
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
