我在这个网站上找到的代码想去跑跑,这个代码应该在linux系统中编写的
- #include <cuda_runtime.h>
- #include <stdio.h>
- #include "cusparse.h"
- #include "cublas_v2.h"
- #include <time.h>
- #ifdef _WIN32
- #include <windows.h>
- #else
- #include <sys/time.h>
- #endif
- #define CLEANUP(s){\
- printf("%s\n", s);\
- if(h_valA) free(h_valA);\
- if(h_csrRowPtrA) free(h_csrRowPtrA);\
- if(h_csrColIndA) free(h_csrColIndA);\
- if(valA) cudaFree(valA);\
- if(csrRowPtrA) cudaFree(csrRowPtrA);\
- if(csrColIndA) cudaFree(csrColIndA);\
- if(h_b) free(h_b);\
- if(b) cudaFree(b);\
- if(r) cudaFree(r);\
- if(p) cudaFree(p);\
- if(Ap) cudaFree(Ap);\
- if(h_x) free(h_x);\
- if(x) cudaFree(x);\
- if(handle1) cublasDestroy(handle1);\
- if(descrA) cusparseDestroyMatDescr(descrA);\
- if(handle2) cusparseDestroy(handle2);\
- cudaDeviceReset();\
- //用于统计程序时间
- double cpuSecond(){
- struct timeval tp;
- gettimeofday(&tp, NULL);
- return ((double)tp.tv_sec + (double)tp.tv_usec * 1e-6);
- int main(){
- //initialization
- cudaError_t cudaStat1, cudaStat2, cudaStat3;
- double* h_valA = 0;
- int* h_csrRowPtrA = 0;
- int* h_csrColIndA = 0;
- double* valA = 0;
- int* csrRowPtrA = 0;
- int* csrColIndA = 0;
- double* h_b = 0;
- double* b = 0;
- double* r = 0;
- double* p = 0;
- double* Ap = 0;
- double* h_x = 0;
- double* x = 0;
- cublasStatus_t status1;
- cublasHandle_t handle1 = 0;
- cusparseStatus_t status2;
- cusparseHandle_t handle2 = 0;
- cusparseMatDescr_t descrA = 0;
- int n, nnz;
- double dzero = 0.0;
- double done = 1.0;
- use CG to solve following linear system:
- Ax = b;
- A = |3 0 2|
- |0 2 0|
- |2 0 1|
- b = |3.5|
- |1.5|
- |2.0|
- correct result x:
- x = |0.50|
- |0.75|
- |1.00|
- n = 3;
- nnz = 5;
- //which device(gpu) to use
- cudaStat1 = cudaSetDevice(0);
- if(cudaStat1 != cudaSuccess){
- CLEANUP("Device Set failed");
- return EXIT_FAILURE;
- //matrix A(csr format) in host
- h_valA = (double*)malloc(nnz*sizeof(double));
- h_csrRowPtrA = (int*)malloc((n+1)*sizeof(int));
- h_csrColIndA = (int*)malloc(nnz*sizeof(int));
- if(!h_valA||!h_csrRowPtrA||!h_csrColIndA){
- CLEANUP("Host malloc failed(A)");
- h_valA[0] = 3.0;
- h_valA[1] = 2.0;
- h_valA[2] = 2.0;
- h_valA[3] = 2.0;
- h_valA[4] = 1.0;
- h_csrRowPtrA[0] = 0;
- h_csrRowPtrA[1] = 2;
- h_csrRowPtrA[2] = 3;
- h_csrRowPtrA[3] = 5;
- h_csrColIndA[0] = 0;
- h_csrColIndA[1] = 2;
- h_csrColIndA[2] = 1;
- h_csrColIndA[3] = 0;
- h_csrColIndA[4] = 2;
- //matrix A(csr format) in device
- cudaStat1 = cudaMalloc((void**)&valA, nnz*sizeof(double));
- cudaStat2 = cudaMalloc((void**)&csrRowPtrA, (n+1)*sizeof(int));
- cudaStat3 = cudaMalloc((void**)&csrColIndA, nnz*sizeof(int));
- if(cudaStat1 != cudaSuccess || cudaStat2 != cudaSuccess || cudaStat3 != cudaSuccess){
- CLEANUP("device malloc failed(A)");
- cudaStat1 = cudaMemcpy(valA, h_valA, (size_t)(nnz*sizeof(double)), cudaMemcpyHostToDevice);
- cudaStat2 = cudaMemcpy(csrRowPtrA, h_csrRowPtrA, (size_t)((n+1)*sizeof(int)), cudaMemcpyHostToDevice);
- cudaStat3 = cudaMemcpy(csrColIndA, h_csrColIndA, (size_t)(nnz*sizeof(int)), cudaMemcpyHostToDevice);
- CLEANUP("memcpy from host to device failed(A)");
- //vector b in host
- h_b = (double*)malloc(n*sizeof(double));
- h_b[0] = 3.5;
- h_b[1] = 1.5;
- h_b[2] = 2.0;
- //vector b in device
- cudaStat1 = cudaMalloc((void**)&b, n*sizeof(double));
- CLEANUP("device malloc failed(b)");
- cudaStat1 = cudaMemcpy(b, h_b, (size_t)(n*sizeof(double)), cudaMemcpyHostToDevice);
- CLEANUP("memcpy from host to device failed(b)");
- //vector r in device
- cudaStat1 = cudaMalloc((void**)&r, n*sizeof(double));
- CLEANUP("device malloc failed(r)");
- //vector p in device
- cudaStat1 = cudaMalloc((void**)&p, n*sizeof(double));
- CLEANUP("device malloc failed(p)");
- //vector Ap in device
- cudaStat1 = cudaMalloc((void**)&Ap, n*sizeof(double));
- CLEANUP("device malloc failed(Ap)");
- //vector x in host
- h_x = (double*)malloc(n*sizeof(double));
- for(int i=0; i<n; ++i)
- h_x[i] = 0.0;
- //vector x in device
- cudaStat1 = cudaMalloc((void**)&x, n*sizeof(double));
- CLEANUP("device malloc faile(x)");
- cudaStat1 = cudaMemcpy(x, h_x, (size_t)(n*sizeof(double)), cudaMemcpyHostToDevice);
- CLEANUP("memcpy from host to device failed(x)");
- //initialize cublas library
- status1 = cublasCreate(&handle1);
- if(status1 != CUBLAS_STATUS_SUCCESS){
- CLEANUP("CUBLAS initialize failed");
- //initialize cusparse library
- status2 = cusparseCreate(&handle2);
- if(status2 != CUSPARSE_STATUS_SUCCESS){
- CLEANUP("CUSPARSE Library initialize failed");
- //initialize matrix descriptor
- status2 = cusparseCreateMatDescr(&descrA);
- CLEANUP("Matrix descriptor initialize failed");
- cusparseSetMatType(descrA, CUSPARSE_MATRIX_TYPE_GENERAL);
- cusparseSetMatIndexBase(descrA, CUSPARSE_INDEX_BASE_ZERO);
- //CG
- //1:
- //max iteration number = 2000
- //relative residual = 1e-7
- //compute initial residual r = b - Ax_0
- //x_0 = |0|
- // |0|
- // |0|
- //initial p = r
- int maxit = 2000;
- double tol = 1e-7;
- double alpha, beta, rhop, rho;
- //r = b
- status1 = cublasDcopy(handle1, n, b, 1, r, 1);
- CLEANUP("Vector copy failed(r)");
- //p = b
- status1 = cublasDcopy(handle1, n, b, 1, p, 1);
- CLEANUP("Vector copy failed(p)");
- status1 = cublasDnrm2(handle1, n, r, 1, &rho);
- CLEANUP("compute norm2 failed(r)");
- rho = rho*rho;
- //2: repeat until convergence
- for(int i=0; i<maxit; ++i){
- status2 = cusparseDcsrmv(handle2, CUSPARSE_OPERATION_NON_TRANSPOSE, n, n, nnz, &done,
- descrA, valA, csrRowPtrA, csrColIndA, p, &dzero, Ap);
- CLEANUP("compute mv failed(Ap)");
- double tmp;
- status1 = cublasDdot(handle1, n, p, 1, Ap, 1, &tmp);
- CLEANUP("compute dot failed(tmp)");
- //alpha = (r^T*r)/(p^T*A*p)
- alpha = rho/tmp;
- //x = x + alpha*p
- status1 = cublasDaxpy(handle1, n, &alpha, p, 1, x, 1);
- CLEANUP("compute axpy failed(x)");
- double tmp2 = -alpha;
- //r = r - alpha*A*p
- status1 = cublasDaxpy(handle1, n, &tmp2, Ap, 1, r, 1);
- CLEANUP("compute axpy failed(r)");
- rhop = rho;
- if(rho < tol){
- break;
- rho = rho*rho;
- //beta = rho/rhop
- beta = rho/rhop;
- //p = r + beta*p
- status1 = cublasDscal(handle1, n, &beta, p, 1);
- CLEANUP("compute scal failed(p)");
- status1 = cublasDaxpy(handle1, n, &done, r, 1, p, 1);
- CLEANUP("compute axpy failed(p)");
- //copy x to h_x, and output h_x
- cudaStat1 = cudaMemcpy(h_x, x, (size_t)(n*sizeof(double)), cudaMemcpyDeviceToHost);
- CLEANUP("memcpy from device to host failed(x)");
- printf("%f\n", h_x[i]);
- CLEANUP("Success!");
- return 0;
复制代码 |
