发表于 2021-8-7 12:17:12
47492
机器:Jetson nano 2G
系统:[url=]Jetson Nano 2GB Developer Kit SD Card Image[/url]  4.5
下载的系统4.5.1版本的MD5死活对不上,所以用4.5版本的
不断重启,疑似没识别出来TF card,然后拔掉TF card也是一样不断重启
拔下过核心板,用橡皮擦过了金手指
电源供电5V-3A
原本是可以的,烧录了新的系统,设置完用户名等进入了系统后,拔掉电源线就再也无法启动了
内存卡更换过了
发表于 2021-8-7 12:20:16
  1. [0000.881] Bootloader downloaded successfully.
  2. [0000.885] BoardID = 3448, SKU = 0x3
  3. [0000.888] QSPI-ONLY: SkipQspiOnlyFlag = 0
  4. [0000.892] Nano-SD: checking PT table on QSPI ...
  5. [0000.897] PT: Partition NCT NOT found !
  6. [0000.900] Warning: Find Partition via PT Failed
  7. [0000.905] Next binary entry address: 0x92c00258
  8. [0000.909] BoardId: 3448
  9. [0000.914] Overriding pmu board id with proc board id
  10. [0000.918] Display board id is not available
  11. [0000.923] No Bpmp FW loaded
  12. [0000.925] Not loading WB0 as no bpmp/sc7entry fw
  13. [0000.930] Set NvDecSticky Bits
  14. [0000.933] GSC2 address ff93fffc value c0edbbcc
  15. [0000.940] GSC MC Settings done
  16. [0000.942] BoardID = 3448, SKU = 0x3
  17. [0000.946] QSPI-ONLY: SkipQspiOnlyFlag = 0
  18. [0000.949] Nano-SD: checking PT table on QSPI ...
  19. [0000.955] TOS Image length 53680
  20. [0000.958]  Monitor size 53680
  21. [0000.961]  OS size 0
  22. [0000.976] Secure Os AES-CMAC Verification Success!
  23. [0000.980] TOS image cipher info: plaintext
  24. [0000.984] Loading and Validation of Secure OS Successful
  25. [0001.000] NvTbootPackSdramParams: start.
  26. [0001.005] NvTbootPackSdramParams: done.
  27. [0001.009] Tegraboot started after 84871 us
  28. [0001.013] Basic modules init took 901435 us
  29. [0001.017] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
  30. [0001.023] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
  31. [0001.028] Next stage binary read took 11286 us
  32. [0001.032] Carveout took -63807 us
  33. [0001.035] CPU initialization took 99964 us
  34. [0001.039] Total time taken by TegraBoot 948878 us
  35. [0001.044] Starting CPU & Halting co-processor
  36. 64NOTICE:  BL31: v1.3(release):b5eeb33f7
  37. ERROR:   Error initializing runtime service trusty_fast
  38. [0001.166] RamCode = 1
  39. [0001.170] LPDDR4 Training: Read DT: Number of tables = 2
  40. [0001.175] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
  41. [0001.188] EMC Training Successful
  42. [0001.191] 408000 not found in DVFS table
  43. [0001.198] RamCode = 1
  44. [0001.201] DT Write: emc-table@204000 succeeded
  45. [0001.206] DT Write: emc-table@1600000 succeeded
  46. [0001.211] LPDDR4 Training: Write DT: Number of tables = 2
  47. [0001.250] Debug Init done
  48. [0001.252] Marked DTB cacheable
  49. [0001.255] Bootloader DTB loaded at 0x83000000
  50. [0001.260] Marked DTB cacheable
  51. [0001.263] Kernel DTB loaded at 0x83100000
  52. [0001.267] DeviceTree Init done
  53. [0001.280] Pinmux applied successfully
  54. [0001.284] gicd_base: 0x50041000
  55. [0001.288] gicc_base: 0x50042000
  56. [0001.290] Interrupts Init done
  57. [0001.295] Using base:0x60005090 & irq:208 for tick-timer
  58. [0001.300] Using base:0x60005098 for delay-timer
  59. [0001.304] platform_init_timer: DONE
  60. [0001.308] Timer(tick) Init done
  61. [0001.312] osc freq = 38400 khz
  62. [0001.316] Welcome to L4T Cboot
  63. [0001.321] Cboot Version: 00.00.2018.01-t210-c952b4e6
  64. [0001.326] calling constructors
  65. [0001.328] initializing heap
  66. [0001.331] initializing threads
  67. [0001.334] initializing timers
  68. [0001.337] creating bootstrap completion thread
  69. [0001.341] top of bootstrap2()
  70. [0001.344] CPU: ARM Cortex A57
  71. [0001.347] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
  72. [0001.352] initializing platform
  73. [0001.359] Manufacturer: MF = 0xc2, ID MSB = 0x25
  74. [0001.364] ID LSB = 0x36, ID-CFI len = 194 bytes
  75. [0001.368] Macronix QSPI chip present
  76. [0001.372] SPI device register
  77. [0001.375] init boot device
  78. [0001.377] allocating memory for boot device(SPI)
  79. [0001.382] registering boot device
  80. [0001.390] QSPI bdev is already initialized
  81. [0001.394] Enable APE clock
  82. [0001.397] Un-powergate APE partition
  83. [0001.400] of_register: registering tegra_udc to of_hal
  84. [0001.405] of_register: registering inv20628-driver to of_hal
  85. [0001.411] of_register: registering ads1015-driver to of_hal
  86. [0001.417] of_register: registering lp8557-bl-driver to of_hal
  87. [0001.422] of_register: registering bq2419x_charger to of_hal
  88. [0001.428] of_register: registering bq27441_fuel_gauge to of_hal
  89. [0001.440] gpio framework initialized
  90. [0001.443] of_register: registering tca9539_gpio to of_hal
  91. [0001.448] of_register: registering tca9539_gpio to of_hal
  92. [0001.454] of_register: registering i2c_bus_driver to of_hal
  93. [0001.459] of_register: registering i2c_bus_driver to of_hal
  94. [0001.465] of_register: registering i2c_bus_driver to of_hal
  95. [0001.470] pmic framework initialized
  96. [0001.474] of_register: registering max77620_pmic to of_hal
  97. [0001.479] regulator framework initialized
  98. [0001.483] of_register: registering tps65132_bl_driver to of_hal
  99. [0001.489] initializing target
  100. [0001.495] gpio_driver_register: register 'tegra_gpio_driver' driver
  101. [0001.503] board ID = D78, board SKU = 3
  102. [0001.507] Skipping Z3!
  103. [0001.512] fixed regulator driver initialized
  104. [0001.530] initializing OF layer
  105. [0001.533] NCK carveout not present
  106. [0001.537] Skipping dts_overrides
  107. [0001.541] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
  108. [0001.557] I2C Bus Init done
  109. [0001.560] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
  110. [0001.570] I2C Bus Init done
  111. [0001.572] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
  112. [0001.583] I2C Bus Init done
  113. [0001.585] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
  114. [0001.596] I2C Bus Init done
  115. [0001.598] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
  116. [0001.609] I2C Bus Init done
  117. [0001.611] of_children_init: Ops found for compatible string maxim,max77620
  118. [0001.622] max77620_init using irq 118
  119. [0001.626] register 'maxim,max77620' pmic
  120. [0001.631] gpio_driver_register: register 'max77620-gpio' driver
  121. [0001.637] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
复制代码
使用道具 举报 回复 支持 反对
发表于 2021-8-7 12:25:38
  1. [0001.647] I2C Bus Init done
  2. [0001.651] NCK carveout not present
  3. [0001.661] Find /i2c@7000c000's alias i2c0
  4. [0001.664] get eeprom at 1-a0, size 256, type 0
  5. [0001.673] Find /i2c@7000c500's alias i2c2
  6. [0001.677] get eeprom at 3-a0, size 256, type 0
  7. [0001.682] get eeprom at 3-ae, size 256, type 0
  8. [0001.686] pm_ids_update: Updating 1,a0, size 256, type 0
  9. [0001.691] I2C slave not started
  10. [0001.694] I2C write failed
  11. [0001.697] Writing offset failed
  12. [0001.700] eeprom_init: EEPROM read failed
  13. [0001.704] pm_ids_update: eeprom init failed
  14. [0001.708] pm_ids_update: Updating 3,a0, size 256, type 0
  15. [0001.738] pm_ids_update: The pm board id is 3448-0003-400
  16. [0001.745] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
  17. [0001.753] pm_ids_update: pm id update successful
  18. [0001.758] pm_ids_update: Updating 3,ae, size 256, type 0
  19. [0001.788] pm_ids_update: The pm board id is 3542-0000-201
  20. [0001.794] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
  21. [0001.802] pm_ids_update: pm id update successful
  22. [0001.832] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
  23. [0001.838] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
  24. [0001.846] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
  25. [0001.852] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
  26. [0001.860] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:1a:6e
  27. [0001.866] Plugin Manager: Parse ODM data 0x000a4000
  28. [0001.878] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
  29. [0001.893] Find /i2c@7000c000's alias i2c0
  30. [0001.897] get eeprom at 1-a0, size 256, type 0
  31. [0001.906] Find /i2c@7000c500's alias i2c2
  32. [0001.910] get eeprom at 3-a0, size 256, type 0
  33. [0001.914] get eeprom at 3-ae, size 256, type 0
  34. [0001.918] pm_ids_update: Updating 1,a0, size 256, type 0
  35. [0001.924] I2C slave not started
  36. [0001.927] I2C write failed
  37. [0001.929] Writing offset failed
  38. [0001.932] eeprom_init: EEPROM read failed
  39. [0001.936] pm_ids_update: eeprom init failed
  40. [0001.940] pm_ids_update: Updating 3,a0, size 256, type 0
  41. [0001.971] pm_ids_update: The pm board id is 3448-0003-400
  42. [0001.977] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
  43. [0001.984] pm_ids_update: pm id update successful
  44. [0001.988] pm_ids_update: Updating 3,ae, size 256, type 0
  45. [0002.018] pm_ids_update: The pm board id is 3542-0000-201
  46. [0002.025] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
  47. [0002.031] pm_ids_update: pm id update successful
  48. [0002.062] Add serial number:1423920056535 as DT property
  49. [0002.069] Applying platform configs
  50. [0002.076] platform-init is not present. Skipping
  51. [0002.080] calling apps_init()
  52. [0002.086] Couldn't find GPT header
  53. [0002.091] Proceeding to Cold Boot
  54. [0002.094] starting app android_boot_app
  55. [0002.098] Device state: unlocked
  56. [0002.101] display console init
  57. [0002.109] could not find regulator
  58. [0002.132] hdmi cable not connected
  59. [0002.135] is_hdmi_needed: HDMI not connected, returning false
  60. [0002.141] hdmi is not connected
  61. [0002.144] sor0 is not supportDT entry for leds-pwm not found
  62. [0002.154] display_console_init: no valid display out_type
  63. [0002.162] subnode volume_up is not found !
  64. [0002.166] subnode back is not found !
  65. [0002.170] subnode volume_down is not found !
  66. [0002.174] subnode menu is not found !
  67. [0002.177] Gpio keyboard init success
  68. [0002.258] found decompressor handler: lz4-legacy
  69. [0002.272] decompressing blob (type 1)...
  70. [0002.337] display_resolution: No display init
  71. [0002.342] Failed to retrieve display resolution
  72. [0002.346] Could not load/initialize BMP blob...ignoring
  73. [0002.421] decompressor handler not found
  74. [0002.425] load_firmware_blob: Firmware blob loaded, entries=2
  75. [0002.431] XUSB blob version 0 size 124416 @ 0x92ca828c
  76. [0002.437] -------> se_aes_verify_sbk_clear: 747
  77. [0002.441] se_aes_verify_sbk_clear: Error
  78. [0002.445] SE operation failed
  79. [0002.448] bl_battery_charging: connected to external power supply
  80. [0002.457] display_console_ioctl: No display init
  81. [0002.461] switch_backlight failed
  82. [0002.468] device_query_partition_size: failed to open partition spiflash0:MSC !
  83. [0002.475] MSC Partition not found
  84. [0002.481] device_query_partition_size: failed to open partition spiflash0:USP !
  85. [0002.488] USP partition read failed!
  86. [0002.492] blob_init: blob-partition USP header read failed
  87. [0002.497] android_boot Unable to update recovery partition
  88. [0002.503] kfs_getpartname: name = LNX
  89. [0002.506] Loading kernel from LNX
  90. [0002.516] Found 19 BFS partitions in "spiflash0"
  91. [0002.836] Failed to validate boot-image
  92. [0002.840] Set to failover in the next boot
  93. [0002.844] fail control word = 0xfbbcc3c1
  94. [0002.848] Rebooting ...
复制代码
使用道具 举报 回复 支持 反对
