我在做关于体绘制方面的内容
我的代码是从CUDA示例程序中的volume render中加以改动而来,但是发现改动以后,kernel函数的运行时间增加到很多,从3ms增加到了186ms,严重影响了程序的运行流畅度。
比较之后发现,我的代码有几处嫌疑最大,比如多了两个纹理读取语句:
float4 startPosition = tex2D(cudafronttex,u,v);
float4 endPostion = tex2D(cudabacktex,u,v);
还多一句求根运算:
depth = sqrt((endPostion.x-pos.x)*(endPostion.x-pos.x) + (endPostion.y-pos.y)*(endPostion.y-pos.y) + (endPostion.z-pos.z)*(endPostion.z-pos.z));
以上是我认为的最有可能的原因。
下面贴出两个代码,并给出我的初步分析,请大家帮我进一步分析一下,非常感谢:
CUDA示例代码,profiler测试运行时间为3ms:
__global__ void
d_render(uint *d_output, uint imageW, uint imageH,
float density, float brightness,
float transferOffset, float transferScale)
const int maxSteps = 500;
const float tstep = 0.01f;
const float opacityThreshold = 0.95f;
const float3 boxMin = make_float3(-1.0f, -1.0f, -1.0f);
const float3 boxMax = make_float3(1.0f, 1.0f, 1.0f);
uint x = blockIdx.x*blockDim.x + threadIdx.x;
uint y = blockIdx.y*blockDim.y + threadIdx.y;
if ((x >= imageW) || (y >= imageH)) return;
float u = (x / (float) imageW)*2.0f-1.0f;
float v = (y / (float) imageH)*2.0f-1.0f;
// calculate eye ray in world space
Ray eyeRay;
eyeRay.o = make_float3(mul(c_invViewMatrix, make_float4(0.0f, 0.0f, 0.0f, 1.0f)));
eyeRay.d = normalize(make_float3(u, v, -2.0f));
eyeRay.d = mul(c_invViewMatrix, eyeRay.d);
// find intersection with box
float tnear, tfar;
int hit = intersectBox(eyeRay, boxMin, boxMax, &tnear, &tfar);
if (!hit) return;
if (tnear < 0.0f) tnear = 0.0f; // clamp to near plane
// march along ray from front to back, accumulating color
float4 sum = make_float4(0.0f);
float t = tnear;
float3 pos = eyeRay.o + eyeRay.d*tnear;
float3 step = eyeRay.d*tstep;
for (int i=0; i<maxSteps; i++)
float sample = tex3D(tex, pos.x*0.5f+0.5f, pos.y*0.5f+0.5f, pos.z*0.5f+0.5f);
// lookup in transfer function texture
float4 col = tex1D(transferTex, (sample-transferOffset)*transferScale);
col.w *= density;
// "under" operator for back-to-front blending
//sum = lerp(sum, col, col.w);
// pre-multiply alpha
col.x *= col.w;
col.y *= col.w;
col.z *= col.w;
// "over" operator for front-to-back blending
sum = sum + col*(1.0f - sum.w);
// exit early if opaque
if (sum.w > opacityThreshold)
break;
t += tstep;
if (t > tfar) break;
pos += step;
sum *= brightness;
// write output color
d_output[y*imageW + x] = rgbaFloatToInt(sum);
我的代码,profiler测试运行时间186ms:
__global__ void
float u = (x / (float) imageW);
float v = (y / (float) imageH);
Ray eyeRay;
eyeRay.d = normalize(make_float3(u-0.5f, v-0.5f, -1.0f));
float3 pos;
pos.x = startPosition.x;
pos.y = startPosition.y;
pos.z = startPosition.z;
depth = sqrtf(pow((endPostion.x-startPosition.x),2) + pow((endPostion.y-startPosition.y),2) + pow((endPostion.z-startPosition.z),2));
if (depth<1e-7) return;
float t = 0;
for(int i=0; i<maxSteps; i++)
float sample = tex3D(tex, pos.x, pos.y, pos.z);
col.w *= density;
col.x *= col.w;
col.y *= col.w;
col.z *= col.w;
if (sum.w > opacityThreshold) break;
t += tstep;
if (t > depth) break;
pos += step;
sum *= brightness;
1、为方便查看,我把以上基本相同的代码标记为蓝色,红色为差异代码。从两个代码上看,在循环处理上基本没差别,在循环之外,我的代码多了两个读取纹理的操作,读取之后有一个求根操作,而CUDA示例代码多了一个 intersectBox函数,但从效果看,intersectBox耗时可以忽略不计。
2、我很纳闷的是,即使是读取纹理和求根操作比较耗时,但那也是在循环之外,每个线程只读取一次,也不至于时间消耗增加那么多,从3ms增加到180多ms
3、那么与我的纹理的动态变化有无关系?我的两个纹理都是512*512,而且是实时动态变化的,而且kernel 函数是循环执行的,kernel 函数在两次执行过程 中,同样的纹理坐标,取到的值是不一样的。我看了资料,CUDA纹理是有缓存的,这种不断动态变化的纹理内容会不会对缓存造成影响,导致缓存摇摆,影响速度?
4、再说明一下,我的两个纹理是从opengl中实时生成,并映射到CUDA中进行使用的,应该也是在设备的global memory中吧,有没有影响?
