流的例子:CUstream stream[2];
for (int i = 0; i < 2; ++i)
cuStreamCreate(&stream[i], 0);
float* hostPtr;
cuMemAllocHost((void**)&hostPtr, 2 * size);
cuMemcpyHtoDAsync(inputDevPtr+i*size,hostPtr+i*size,size,stream[i]);
for (int i = 0; i < 2; ++i) {
#define ALIGN_UP(offset, alignment) \
(offset) = ((offset) + (alignment) – 1) & ~((alignment) – 1)
int offset = 0;
void* ptr;
ptr = (void*)(size_t)outputDevPtr;
ALIGN_UP(offset, __alignof(ptr));
cuParamSetv(cuFunction, offset, &ptr, sizeof(ptr));
offset += sizeof(ptr);
ptr = (void*)(size_t)inputDevPtr;
offset += sizeof(ptr); ALIGN_UP(offset, __alignof(size));
cuParamSeti(cuFunction, offset, size);
offset += sizeof(int);
cuParamSetSize(cuFunction, offset);
cuFuncSetBlockShape(cuFunction, 512, 1, 1);
cuLaunchGridAsync(cuFunction, 100, 1, stream[i]);
cuMemcpyDtoHAsync(hostPtr + i * size, outputDevPtr + i * size, size, stream[i]);
cuCtxSynchronize();
cuStreamDestroy(&stream[i]);
事件的例子:CUevent start, stop;
cuEventCreate(&start);
cuEventCreate(&stop);
cuEventRecord(start, 0);
cuMemcpyHtoDAsync(inputDevPtr + i * size, hostPtr + i * size, size, stream[i]);
int offset = 0;
void* ptr;
offset += sizeof(size);
cuEventRecord(stop, 0);
cuEventSynchronize(stop);
float elapsedTime;
cuEventElapsedTime(&elapsedTime, start, stop);
cuEventDestroy(start);
cuEventDestroy(stop);
1:这两个例子在发射完内核后,调用同步的函数不一样。一个是cuCtxSynchronize();一个是cuEventSynchronize(stop);我想问:对流的同步有cuStreamSynchronize();函数吗?
2.对事件同步可以用cuCtxSynchronize();吗?
3、事件和流的各自作用是什么?有什么联系没有?谢谢。请介绍的形象一点。十分感谢
