cuda by example第四章那个Julia的程序:
#include "../common/book.h"
#include "../common/cpu_bitmap.h"
#define DIM 1000
struct cuComplex {
float r;
float i;
cuComplex( float a, float b ) : r(a), i(b) {}
__device__ float magnitude2( void ) {
return r * r + i * i;
__device__ cuComplex operator*(const cuComplex& a) {
return cuComplex(r*a.r - i*a.i, i*a.r + r*a.i);
__device__ cuComplex operator+(const cuComplex& a) {
return cuComplex(r+a.r, i+a.i);
__device__ int julia( int x, int y ) {
const float scale = 1.5;
float jx = scale * (float)(DIM/2 - x)/(DIM/2);
float jy = scale * (float)(DIM/2 - y)/(DIM/2);
cuComplex c(-0.8, 0.156);
cuComplex a(jx, jy);
int i = 0;
for (i=0; i<200; i++) {
a = a * a + c;
if (a.magnitude2() > 1000)
return 1;
__global__ void kernel( unsigned char *ptr ) {
// map from blockIdx to pixel position
int x = blockIdx.x;
int y = blockIdx.y;
int offset = x + y * gridDim.x;
// now calculate the value at that position
int juliaValue = julia( x, y );
ptr[offset*4 + 0] = 255 * juliaValue;
ptr[offset*4 + 1] = 0;
ptr[offset*4 + 2] = 0;
ptr[offset*4 + 3] = 255;
// globals needed by the update routine
struct DataBlock {
unsigned char *dev_bitmap;
int main( void ) {
DataBlock data;
CPUBitmap bitmap( DIM, DIM, &data );
HANDLE_ERROR( cudaMalloc( (void**)&dev_bitmap, bitmap.image_size() ) );
data.dev_bitmap = dev_bitmap;
dim3 grid(DIM,DIM);
kernel<<<grid,1>>>( dev_bitmap );
HANDLE_ERROR( cudaMemcpy( bitmap.get_ptr(), dev_bitmap,
bitmap.image_size(),
cudaMemcpyDeviceToHost ) );
HANDLE_ERROR( cudaFree( dev_bitmap ) );
bitmap.display_and_exit();
错误是:
1>G:/CUDA/code/julia2/julia2/kernel.cu(27): error : calling a __host__ function("cuComplex::cuComplex") from a __device__ function("julia") is not allowed
1>
1>G:/CUDA/code/julia2/julia2/kernel.cu(28): error : calling a __host__ function("cuComplex::cuComplex") from a __device__ function("julia") is not allowed
1>
1>G:/CUDA/code/julia2/julia2/kernel.cu(15): error : calling a __host__ function("cuComplex::cuComplex") from a __device__ function("cuComplex:perator *") is not allowed
1>
1>G:/CUDA/code/julia2/julia2/kernel.cu(18): error : calling a __host__ function("cuComplex::cuComplex") from a __device__ function("cuComplex:perator +") is not allowed
是不是又有哪里没设置好啊
