from PIL import Image
import numpy as np
import pycuda.driver as cuda
import pycuda.autoinit
import tensorrt as trt
trt_logger = trt.Logger(trt.Logger.WARNING)
def build_engine(model_file):
builder = trt.Builder(trt_logger)
network = builder.create_network()
builder.fp16_mode = True
parser = trt.UffParser()
builder.max_workspace_size = (1<<30)
parser.register_input("input_1",(1,28,28))
parser.register_output("dense_1/Softmax")
parser.parse(model_file,network)
return builder.build_cuda_engine(network)
def do_inference(context,bindings,inputs,outputs,stream):
cuda.memcpy_htod_async(inputs[1],inputs[0],stream)
context.execute_async(batch_size=1,bindings=bindings,stream_handle=stream.handle)
cuda.memcpy_dtoh_async(outputs[0],outputs[1],stream)
stream.synchronize()
return outputs[0]
def main():
test_num=6
data_path = str(test_num)+".pgm"
model="lenet.uff"
engine = build_engine(model)
stream = cuda.Stream()
bindings = []
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding))*engine.max_batch_size
dtype = trt.nptype(engine.get_binding_dtype(binding))
host = cuda.pagelocked_empty(size,dtype)
device = cuda.mem_alloc(host.nbytes)
bindings.append(int(device))
if(engine.binding_is_input(binding)):
inputs = (host,device)
else:
outputs = (host,device)
context = engine.create_execution_context()
img = np.array(Image.open(data_path)).ravel()
np.copyto(inputs[0],1.0-img/255)
result = do_inference(context,bindings,inputs,outputs,stream)
prediction = np.argmax(result)
print("test_num: "+str(test_num))
print("prediction: "+str(prediction))
if __name__ == '__main__':
main()
